Transmissions- how common?
At about 45,000 miles it started dropping from 4th to 3rd under load. If I held a steady speed in 4th, it seemed to be OK, but, if I twisted the wick, it could suddenly jump out of gear and grab 3rd without even touching the shifter. Once that happened, I immediately parked it and started pulling the engine before any severe damage could occur. Thank God for Robinson Industries. I pulled the engine and had Carpenter Racing do the tear down and reassembly. They work with Robinson on trans repair. Both outfits do good work in my humble opinion.
How much did that cost? details ? appreciate it
As they say, "If you gotta ask, you can't afford it." I saved a lot by pulling the engine and reinstalling it myself. Some Captains go further and save by disassembling the engine, too. Then they send the trans parts directly to Robinson. That also saves on shipping because the components are a lot lighter than the whole engine. First I built a nice wooden box for the engine. In retrospect, I should have secured the engine better. I had one ratcheting strap holding it down, it worked loose during transport. No serious damage. I hired YRC to ship it from Tucson to NJ for about $280. On the return trip, I had trouble working with YRC, so I let Carpenter use their shipper which costs $590 back To AZ. Undercut gears - $490, billet 4th gear - $270, labor - $900. Additionally, I had bought some new trans parts like shifter forks to be installed during the rebuild - whether it needed or not. I also requested new trans bearings, needed or not, to start out fresh, but Robinson elected to go with the old ones. I paid $13,000 for my R3R new in 2014, so I don't mind investing some more. Nowdays, you can pick up a clean, low mile, used Roadster for much less and can afford to pump a few grand into it to make it bullet proof and/or more powerful. My engine dynoed at 230HP /170 ftlbs @ the rear wheel. It is an incredible machine.
Yeah thats alot i probably couldn’t afford or capable of doing all that, thanks for the breakdown on how you did it
The undercut price seems quite high. Mine was AUD 350 which would have been around USD 250 at the time. Caveat - I dropped off the input/output shafts completely parted so my guy literally got straight to grinding then reassembled
