Copart has a 2010 Roadster they will be auctioning off in Canada I thinkl Alberta. Looks like the front end took the hit amd the engine is fine only 8000 miles on her. You should see if you can get it cheap and then just stuff the engine in yours. You'd probably make some money parting out the rest of the stuff. Just an idea that might be easier for ya.
Now once you get it back up don't pull the clutch in and rev the tits off it or you'll be replacing lifter shaft and lifter piece. In fact you can get the same resulting feeling if you hit yourself in the groin with a 3 lb. Hammer :)
Curious......... how many miles are on the clock, TriumphRIIINewB???
Cannot answer for MrNewbe but I have 70000miles on my 2005std ans still the original TPS , as I have said numerous times before my 2005 Rocket is/must be one of the most reliable bikes that Triumph ever built and I am going back to when the Germans owned triumph.
