Towing an R3
i guess the answer is yes the motor needs to be running to lube the trans. even if the motor was running the final drive would be turning at least one shaft in the trans and might still do damage i am fairly sure it was not designed to work like that.
all things considered if i broke down a few blocks from my house i would wrap a tee shirt around my forks and wrap a tow rope around the tee shirt a couple of times and hold the rope at the throttle (so i could turn it lose if i got into trouble) and let my wife tow it home.
knew a guy that did that with his hardley stupid sob never let go of rope or bike wife drug him for a block or so till he could not hang on anymore he went to hospital bike got thrown in back of pivkup
For only $49 per year get insurance thru the AMA and never worry about towing as you will be flat bedded. They also include your cage and motorhome if you have one along with most everything else AAA gives you except the high price!:)
I have had AAA for many years and don't believe $49/year is correct, Amigo.
Tis more like $149 for the RV / MC version, which includes up to 6 tows per year up to 100 miles each tow.
You can use a tow for another riding buddy if you wish.
my first plan A was to hold the small rope in my hand and i don't know why i decided to check the brakes just as she was taking off it pulled me wright over the bars. so as i was sitting there on the ground in front of my bsa:roll::roll: i came up with plan B which worked really good.
