TORS and Ramair - need a tune that's in-between...
I'm sure they do. If you can't find one on eBay go to the dynojet web sight (the company that makes power commander) and they should have them since it's a dynojet product. Maybe also google dynojet lambda sensor bypass for your year model. That may pull it up from British customs or revzilla, j&p, ect...
This is a great informational thread for me. When I replace my stock exhaust and add Ramair, it will serve me well. Thanks guys, for all the smarts that I will be needing later!!! uhm00000.gif
I just loaded the tune. I don't have the sensor bypass yet, so I left the sensor plugged in and checked. I don't have access to a dyno, but I will see if I can observe any difference between having the sensor and removing it. I will report back any observations.
Just uncheck the sensor even if you don't remove it yet. I ran for a while with it still in. The tune will run better with it unchecked though
After you download the tune don't forget to turn ignition off for a minute, then back on, run iscv check, tps check, then run reset adaptives, then crank engine without touching throttle, warm up until fan kicks on, then let idle for 12 minutes :thumbsup:
Well I had to go meet some people for a ride. Didn't have time to do the 12 minute tune, I will do it tomorrow.
That said, the bike has never run better. This is a great tune. I would love to know how much horsepower increase I am getting. I can definitely notice the difference. On top of that, I have zero deceleration popping.
Thanks again. I will report back once I get the O2 bypass installed.
Write your reply...
