Told PCV Not Recommended.....By Dealer
Oh, I should clarify that...I didn't mean physically remove them but adjust the % they are open in the lower gears and RPM's. What you said seems in line with what he was talking about. Thanks.
Just be patient and read as much as you have time for here on R3. Here is a lot of information here.
I'd suggest define what you want to do, what are your power goals and people can advise you on the best path to get there, with the least headaches.
some will argue that you should leave them partially working to smooth the bottom end but the tweaks I have put in to the tunes seems to have the same effect, at the end of he day the choice is yours, contact me when/if you decide what you actually want
Ah but with both - imagine!
