Time for a new rear tire, car tire or bike tire ?
I wouldn't put a car tire on a bike any more than I would put a bike tire on a car. There's a reason they're not square. How do you turn a motorcycle? By leaning. What happens when you lean? Question answers itself.
Will the extra 1/2" affect the ABS at all? Will the bike rest 1/2" taller or how much taller? I barely can touch both heels to the ground at the same time with a 30" inseam and a modified seat. THANKS
The 1/2" doesn't mess with the ABS, and actually only raises the bike 1/4" in the rear. You won't regret the upgrade.
Today i spied another sharp bit of metal hanging out between the tread on my rear tire , removed and plugged, thats now 2 plugs in that tire , really need this tire to last another 5-6 weeks , that way i can have the new one put on just before RDU
What do you use to plug holes? If there is no leak yet how well do you trust the plug? I've had almost 1 tire screwed per year for the last 4 years...
Try this out http://www.ride-on.com/
I've been running it in my Excedra Max rear for a couple thousand miles and seems to work great
Thanks Steel, I should get the "radial" version right? (not even sure if both options are available...)
