Stuck in fifth and clunking, -after advice, hints tips and tricks TIA
I would check the detent spring first. Relatively much easier to check and it may be the problem.
Manual and detent spring instructions are in my signature link.
Might be worth pulling the front cover for a look tomorrow, cheers 👍
Gday Trav and welcome...first thing to do is buy another bike while you sort this mess out...Tassie riding is too good to miss out on...
If you got this far you might as well finish the job and rebuild the trans completely - at least then you will have peace of mind. I've replaced gears with only 10k km on them and the dogs were already badly worn.
Isrub's suggestion would probably be the most cost effective but you have to find a donor bike and most likely get it across on the Spirit somehow etc ...lots of time and risk in an already worn trans.
I reckon 4th 5th out and 3rd in will look a lot like this....
Ha haha my rh
Haha, I'm leaning towards this
Time will tell, I keep telling myself it's Winter it's Winter..... Not that it hardly matters
It is a pretty easy job, waiting on the parts delivery is the frustrating bit
Always is, it's never a 5 minute job either lol
Hoping to get the gearbox fixed properly, have been given a couple of mainland options
Also need to finish getting her apart for proper diagnosis
Dang! You work fast! So, tomorrow is engine tear down, rebuild, reassembly, install, tune and break in? What will you do after lunch?
Hahaha not quite, this will be months yet, still my fingers are crossed
I need this tool (see attached) to pull the alternator, everything else I can wing, does anyone know an ""alternative"" method?
Wow I wish I had your garage and resources. I am looking at maybe the same :( 4th gear is messed up on my 2011 R3R right now, started yesterday. First step to drain and drop the sump to see if can see any shards or bits of cogs etc.
I've borrowed that (and the bar that goes with it) from the dealer a couple of times. I had planned to take that schematic to a machinist along with a couple of cartons but haven't got around to it yet.
My alternative was to source a bolt that matched pitch and diameter and taper the end to fit...but haven't got around to that either...i have an 11 month old so spare time is a long forgotten luxury...
A 3rd option is order one from Triumph if you are feeling wealthy!
We will take this opportunity to summon @Mittzy and @Ishrub who might know of one on the east coast somewhere...both are resourceful fellas :thumbsup:
Write your reply...
