TURBO200R4
stand up straight and grab the world by the a$$
mines 2008 and having the same issues, waiting to see what you find out
my bike has 15.500 miles I'm the 3rd owner and just completed the test on my stator myself turns out I should have done this in the first place
My readings
any pin to engine ground = OL
PINS
1-2 0 omhs 0 volts
2-3 0 omhs 0 volts
3-1 0 omhs 0 volts
Really hard to believe with suck low miles
Hi oldwarrior
where are you checking to get these results?
i am assuming that you are checking at the connector to the regulator and it is unplugged.
have you checked volts from bat, fuse 11,at the reg. also bat neg from bat to reg connector.
do a voltage check across all fuses.
you never said what happen when it went bad. to much charge or to little charge, no charge.
what is happening to the bike?
