Late to your thread, but have you increased the pos & neg bat cable sizes? I doubled up with an extra set and twas much more power in the start!
I used 2/O - 3/0 welding lead fine stranded cable for both the Pos. & Neg. cables, one each. No problem since. I did install the bigger starter and rebuild kit in the solenoid.
I just bypassed that plug & ran a wire from solenoid plug to starter relay black wire.
Solved my starter clicking issues after trying everything else. 🚀
hi. 2 questions please.
1)Is it running a wire from here to black(87) of starter relay?
2)Is it the original 5 pin starter relay or the mod 4 pin?
Much appreciated.
Much appreciated.
Yes from starter plug straight to thick black wire 4 pin plug.
The wire from relay to starter just goes into loom & out...it doesn't branch off to anything else in loom.
Thanks. Will try out.
Am waiting for my mod 4pin relay to arrive.
So the old black from original 5pin...doesn't need to be connected at all? Since I have this thicker red to the new 87 of the 4pin relay.
Correct?
Correct?
The wire is originally black, but going red or any color all good. I ran the wire inside protective tubing as well 👍🚀
I said it b4 and i will say it again if the starter solenoid is clicking then all the safetys are working along with the relay. So either you're not getting enough voltage at the starter solenoid
(Witch i dought) or you have a starter problem. I would recommend another starter solenoid or if you bought that starter then try to exchange it for another one.
Just because the solonoid clicks, does not mean it is working...... bad/dirty/burnt contacts not passing current through to starter....
