Mongler07
Turbocharged
Buy a cheap old bike... Expects no problems!
Oh boy!
I have this issue with 2nd but not in any other gear. So I suspect it's not the dogs but it could be.
Drive shaft is probably the issue
It could also be a ignition issue. The coils on these beasts are pathetic.
Replace spark plugs and go with over head coil mod. Very cheap and if you can crimp /solder wire you can do it.
The injectors also have a issue of clogging up. You can have them cleaned professionally for under $100
I highly recommend you do not bother trying to clean them diy.
Past this... Might be an electrical issue but let's start at the beginning first with known issues.
Oh boy!
