Something Failed, let’s find it! Transmission Analysis.
You know, one thing that I learnt when modifying M/C's is that under "normal" circumstances, "normal" being what the Factory built, many things that are good enough, break or wear out faster when the original Factory assembly/production is exceeded by people like us who just can't leave things alone and want to make them go faster.
Similar things go on in the Four wheel drive world....It's painfully easy to identify the weakest part of your machine...but when you beef it up, you reveal the next weakest link....and so on, until you are into it with huge money...but you have an unbreakable vehicle.
Here’s my train of thought so far;
Theory:
Gears 1-4 and 2-3 share forks so:
When going 3-4, both forks are activated. If one were they were offset a little too far to one side, as it appears mine are, then the engagement and disengagement will occurs at slightly different times, getting worse over time as the fork abnormally wears.
As a result there’s a potential for a side load applied to the third gear circlip as things move. Eventually with wear, both gears will try and be engaged at once, generating a massive axial force against the circlip as third output tries to move out of the way.
Once the circlip moves third wobbles and is engaged at an angle, and you rip teeth off one side like I did.
Anyway, that is my theory with what I’ve found so far.
I should mention, my theory basically correlates with how I ride. Wear would be accelerated at high speed and high load.
Well... 170+ lbft
I like to haul ass, typically riding no slower than 70 unless cars are briefly in my way, and often cruising in the 90-110 range.
Robinson wants it back to look at it, will get the gears on order Friday and ship the in/out shafts to them.
He did key in quickly on “were you using some sort of Quickshifter/Airshifter” and I didn’t prompt it.... me thinks root cause analysis may be complete lol.
We’ll see.
Part 2: what is the jiggling/rattle while in 5th at part throttle at 2900-3100 RPM.... this I’ll try and get solved tonight.
It is just possible they also read this forum and it was mentioned earlier that you were using a Quickshfter. ;)
bob
We’ll see.
@Claviger that could also be what i call my slapping noise felt at that range of RPM please let us know what comes out your investigation on this specific situation
Looking closely I’m rethinking my theory.
I need to sit down when I get home and really apply some grey matter effort but because of the way they broke I am confident a walking circlip was absolutely not the cause but instead a symptom of the breakage.
Write your reply...
