Shaft Splines
Thanks Turbo, that makes sense to torque the shaft nuts, in sequence, before torquing the axle. It looks like rust but I think it is just the factory dry lube, but i will clean it up before applying the moly 60.
Yeh it's dried up lube by the look of it. You're fortunate it's worn so well considering your mileage. Mine was chewed up pretty bad at 96,000klms. New diff here in Australia was $2,000. Was a bit of a sh!tfight to get it replaced under warranty .. they reckoned the mileage was too high.
They are worn but hey you might as well get your moneys worth out of it. I would start keeping a eye out for another rear end and drive shaft.
I thought this was the other way round?
Tighten the axle first and then the drive shaft?
I think I have already got my moneys worth, but being Scottish I am going to squeeze every last drop I can....
For those of you who have not done this before, the inner ring behind the the shaft splines is a foam collar that you need to bring forward over the shaft splines to support it so you can easily reinstall the final drive. It took me a while to figure this out. You will not be able to get the final drive back on without this foam collar. I had to put some wd 40 in between the collar and the shaft cover and use a hanger to bring it forward over the splines.
+1 on this. Nip the final drive bolts up lightly then tighten the axle shaft to align it then torque the final drive nuts.
MANUAL SAYS
before tightening the bevel box nuts, fully insert the wheel spindle through the swing arm to ensure it will realign with the swing arm when the wheel is installed.
then it tells you how to tighten the nuts then it tells you to put on the tire.
