Shaft Splines
The good
The bad
The ugly
Now if only you'd been lubed from birth you'd be lookin like a spring chicken nowadays Fred.
So what do you think? I don't think they look that bad. In any case its going back together as is with generous honda moly 60.
that looks like rust if it is i would clean it up before lubing.
you can move the shaft around and tell if there is any binding on the front ujoint.
i would put it all together and before tightening the axle bolts i would tighten the nuts to the drive shaft tube first.
just looked in manual torque first to 20Nm then to 64Nm.
the manual has a tightening sequence looking at pic should be inside top** out side bottom**inside bottom** outside top.
Thanks Turbo, that makes sense to torque the shaft nuts, in sequence, before torquing the axle. It looks like rust but I think it is just the factory dry lube, but i will clean it up before applying the moly 60.
