I don't think the colours matters at all, unless the actually coating differs in thickness or density because of it
Surely black body radiation theory relates more to something being exposed to radiation/heat from the outside and not from the inside. From the inside an exhaust pipe will be the same and as long as the ceramic coating is the same thickness and density regardless of colour it will radiate the same heat out.
Hi kaivalagi,
It doesn't matter whether the object is exposed to the energy on the inside or the outside. Those two surfaces could be different colors and if at the same temperature, would radiate energy differently.
Mark
Not being smart or trying to offend anyone but I don't really care what fuel mileage I get. If I wanted fuel economy I wouldn't be riding a Rocket.
Fair comment. It's just nice to be able to get a couple of hundred miles out of a tank when I'm in the groove.
Mark
I do recall back when I did some camping as a kid that the good old blacked pots would boil water faster than a shiny silver one. I was told that the black absorbed and retained more heat. Makes sense to me.
Mark
That's true I don't care about fuel economy but another 3 or 4 litre capacity would be handy or dare I say it better fuel economy. There I think I just shot down my own argument. Wouldn't that f#ck you.
Hi TOMCAT,
That bloke is incorrect. The effect is described by Max Planck's theory of black body radiation. The link is rather more in- depth than warranted, and a better example is a commonplace situation: A white car and a black car are both out in the sun, - which feels hotter to the touch?
Mark
Ok, you finally you got me racking my brain as well, over this... :banghead:
Radiating light and heat is just about the same thing, and black will radiate less of both.
Black pipes will keep more heat inside (just like a black car), and therefore run slightly hotter on the surface.
Light pipes are a bit cooler - but just because their heat is being radiated and transferred to your leg, all the time!
So Tomcat's bloke was right, black pipes will give you slightly cooler legs.
Getting back on the thread's topic, as long as I can get approval from SWMBO I'm going to order a CES system. Leslie told me in an e-mail that they can supply a set of K&Ns too along with a Tune ECU map, - so the whole enchilada is available from them. I think that's a great package,
Mark
