Ogremeister
Turbocharged
There is a trap associated with this, going two up into a good lean and hitting a depression on the curve. The shocks compress more than usual and you scrape more than you bargained for. Unless you have explained to the pillion rider that you want them to lean off the bike with you, you would probably just hook into the corner.
Quite true.....BUT.....with proper adjustment of the rear shocks and proper technique, the depression on the bend will cause you to scrape (NOT HOOK, CRASH, LOW-SIDE) because you would not be riding that close to maximum inclination.
I train my pillions to give me room a freedom of movement, allowing me to roll my weight in the seat.
I also train them to become "one with the bike" .......
Yes, they "could" help by leaning...BUT...I loose some control and predictability.
When they are "with the bike" it is more predictable AND you know they are NOT leaning the wrong way....making things harder.
