RobTremblay
Roadster ABS Manual
Great info about the Roadster Manual- I have a new Roadster Service Manual on order from one of the large Triumph dealers in Toronto. Am I correct in assuming the Roadster/ABS Supplement T3851190 will be included with the Roadster Factory manual? As part of the manual package?
I just picked up the service manual supplement for the Roadster which is almost entirely about the ABS and contains instructions on bleeding the brakes. It is only $10 from the dealer and the part number is T3851190.
It says you need the Triumph diagnostic tool (opens the ABS solenoid) to bleed the ABS modulator of trapped air. Does anyone know if the TuneECU software can do this procedure? Or is there another tool that allows for opening of the ABS solenoid to allow bleeding of the brakes?
Basically it says to bleed the brakes like non-ABS models, then bleed the ABS modulator using the diagnostic tool, then repeat the brake bleed like a non-ABS model.
I certainly don't want to pay the dealer to do this if there is a way to do this myself.
