warp9.9
Pocałuj mnie w dupę
I change my levers to pazzo racing they allow more adjustment then the stock ones. But then I have a lock up clutch now and they do not have as much clutch head movement as the stock system.
is your arm down on the clutch cover floppy or is there good tension on ? You can accuate the stock clutch by hand there to feel the tension and when it contacts the lifter piece head do not rotate it more then 30 degrees once you feel the lifter piece contact. there is also a return spring that fits around the small end of the lifter shaft which IMO could be a higher tension one.
