Valaas
Turbo
I'll do the vacuum test on each blinded line just to confirm leaks on #2 and 3, but I have ordered everything elastomer oe that see vacuum including the blind caps. Willing to go to extreme steps if nexessary to reduce the risk of a vacuum leak chase again.OK good so MAP sensor may be ruled out.
You could try put the vacuum gauge (on a short piece of hose!), connected to each of the 2nd set of nipples on the throttle body, in place of each blank, one at a time.
The idea is to see if there is a vacuum leak on any of the 3 cylinders' throttles.
I doubt all 3 transition pieces have the same leak.
You know, all this started with a turbo upgrade project. I have had all necessary hardware in my garage for 3 weeks ready, to start fitting, but wanted to spend a couple of days getting the engine basics tip top. Man, did that plan fail miserably.
"Forced air project stopped by vacuum" :-/
