Larry_M
- Joined
- Apr 16, 2020
- Messages
- 320
- Ride
- 2019 Triumph 1200 Scrambler XC, 2020 Rocket 3 R
I haven't had time to adjust the fork yet, we've had a couple of days of heavy rain here.All the settings are maximum counter clockwise already. Tyre pressure is at 2.7 bar instead of 2.9 given in the operating conditions.
I asked yesterday to my dealer to ask to Triumph (or Showa) if it is possible to use a less viscous oil in the shock.
I will try today to get the fork a bit softer as you did. Did you turn softer both TEN and COMP ?
Did you try adjusting preload up 6 - 9 clicks from minimum in the rear? I know it sounds like the totally wrong thing to do but there is such a thing as undersprung and overdamped.. Might be worth a try? It should be possible to change rear spring and/or oil, and maybe even re-valve the rear shock. It will take time though before the aftermarket catch up with new models, especially if there's not a lot of people agreeing something is "wrong"
