Ugarte
Turbocharged
If do a Ramair kit it will be permanent. As any other mod I may do, I hope before I do it, it will be well considered, and only a forward from here proposition.
That said, I went back to stock exhaust on my Suzuki, since my experimental setup was not to my liking, and a stock set in fine shape came available at a screaming good price!
What I meant was, there are a number of maintenance items that require removing and re installing the stock intake, ie spark plugs, valve check, throttle body work, and it is so much easier if you do not have to re install all that garbage when you do the maintenance work.
