Im home ma
Ya I was with Dr.D and the crew right up to that curve. Then I brain farted :)
After seeing that you were not behind us I went back to check on you. From around the corner I could tell that it was not a good deal. I was hoping you’d have another flat.:roll:
Love ya brother and I’m glad it wasn’t any worse that it was. We all make mistakes but I’m happy to see you walk away even if a tad broke up.
Nice to have met you.
In case it wasn't mentioned, fixing the speedo will throw off the odometer an equal amount with OEM tires. I'm not sure about those monster tires...
ECM cable = Diagnostic Interface for TuneECU Motorbikes
TuneECU software = Overview En
Windows is freeware.
The Android version is on Google Playstore. More info is at Android En
As discussed, your throttle bodies are a bit off but were in spec. You could sync them up with TuneECU to run even smoother. Info is in other posts.
If you choose to clear smurfs throat and let him/her breathe properly there are TuneECU Hex maps in the Resources tab above or on the TunECU site.
Note they are specific to certain serial number ranges or touring.
Thanks Jim.
WTF Warpo!
Please explain that photo.
Not really much to explain Bull I was in a curve had some loose gravel that kicked the bike out and eventually I tried missing the mail box post and the steel sign unfortunately there was not enough room so the sign went flying and stuck in the ground past the driveway. The bike barley made. Across the driveway the gravel slowed it down. I went for a flight like the sign but not as far as the sign. I know my clavicle broken, possibly in more then one break from feeling the bones moving. Hopefully when I get back to Norfolk today I can get it looked at to see if it need a plate or if it is good enough to let heal in place. I'd post pictures but after two days my left side of my chest is all purple and doesn't look to good. Got to get ready to hit the road.
Thanks bud that was the first time I've ever got a ride on a Indian . ;)
