JMO
it is there so if someone that knows nothing about your bike if you have a wreck has something to turn off.
when we were running mud bogs we had to install a switch on the back with a pull pin and they attched a 100 yard cord so if the throttle stuck from the mud when you came out of the bog it would kill the motor.
i know we went on some wild rides.
The switch, which is only used in some markets is a failsafe. If you kill the master switch on the side of the bike the engine will have to remap its self when restarted. Avoid this if possible. Only use the kill switch if the bike is on fire!
Write your reply...
