Einar
.060 Over
- Joined
- Jan 14, 2024
- Messages
- 184
- Location
- Los Estados Unidos
- Ride
- '24 Rocket 3 GT & '23 Tiger 1200 GT Pro
I made the exact same move.
1. None other than paint, excluding the "tune" on the Storm.
2. Both of my Triumphs are noticeably lower on the quality scale compared to the Harleys I've owned, mainly around electronics and materials, but I'm used to that in Euro bikes. But there's nothing that's a deal-breaker. Because the Rocket was designed around the engine, some regular maintenance is far more involved (such as air filter refresh), and you'll also have the addition of water cooling. But nothing too bad beyond what you noted.
3. I have no feedback, as I avoid buying used under any circumstances.
4. I got my 2024 at MSRP.
5. Yes, there are crash guards, but honestly they look like they'd do little and even put your bike at additional risk of damage. But that's pure opinion.
6. The horn is ****e. Get at least a Sound Bomb Mini (if you don't want to do any wiring) or something better.
I made a similar move, from a Street Bob 114. I went from two Harleys to two Triumphs mainly because I tried to pick up a Low Rider ST, but they tried to fleece me for $6,000 over MSRP, so I said "screw it" and decided to give Triumph a try.Hello, I currently ride a 2019 HD fatbob 114, and am looking to switch to a Rocket 3 GT. A few questions that hopefully some of y'all would be able to help answer
Thanks!
- Any significant difference between a 2023 and 2024/2025 models? 2023 seems to have about $4k off MSRP and some dealers have a few new 2023 available
- My current ride has been fairly trouble free - regular oil changes and that's about it (about 20k miles on it). With R3, it looks like I will need valve clearance check (and adjustment if needed) after 15-20k miles (in addition to the oil changes). Other than that, any other maintenance that I should be aware of? Any common issues that I should be aware of?
- There are a few 2022/2021 model used R3s available with under 6k miles - prices around $13-16k. Should I steer away from those? I've never bought a used motorcycle (the HD, the CBR600 and other bikes) - is the R3 built well enough to handle potential abuse in the first 1k miles etc?
- Are 2025/2024 R3 GTs typically sold at MSRP? Or is there typically room to negotiate? (Dallas/TX area)
- Are there any engine crash guards available for the R3?
- How anaemic is the horn? (Assuming it is like every other motorcycle out there, how easy is it to add a high-low combination pair of horns?)
