I have a 2023 triumph rocket 3r and I was wanting to change my throttle in sport mode from 60% to 100%.
I was going to use Alf penner map 31018 which is supposed to be unrestricted and it’s not.
Its throttle values are still 61.2% on etv 2&3 so you are not going to get power gain from the throttle.
If you want the 100% throttle from you bike looks like you will have to change the throttle values yourself by paste and copy.
Has anybody check the values themselves and what is your opinion?
Cheers Wayne.
Consider the very easy and effective BT Moto tune. Produces a 35 HP increase and increases red line to 7500 rpm. No mechanical changes needed.
I have recently installed the BT Moto tune into my 2021 R3 GT. The difference is very real especially at the high end of the now increased rev range.
35 HP increase and rev limit> to 7500 rpm. Easy w/o any mechanical changes needed. Highly recommend this.
The company (in Mass.) sends you a small module into which you load your ECU program, send it back to BT. They change the tune to their program and send it back to you. Voila!
How much additional hp do you see above 7000 rpm? Also, you have the opportunity to compare the Penner unrestricted tune to the Bren tune. That would be interesting?
Can you share the map reading off TuneECU so those who know how to make sense of such things can compare it with Penner's Tune? That's what I'm running and very happy with it, but naturally curious what kind of voodoo BT Moto has up their sleeve.
Write your reply...
