Vee
- Joined
- Dec 11, 2012
- Messages
- 16
- Ride
- Roadster 2013
Last evening I swapped relay, but no luck.P0108 is intake manifold pressure and p0113 is intake temp check the plugs that you have disconnected when you fitted the ram air, also the start relay behind left side panel the manual will tell you which is which you can swap the fan one with the starter one to see if that is a faulty relay. I have an 08 classic so you may need to refer to the roadster manual for exact location.
Here is the video.
Triumph Rocket 3 startup problem:
