Odometer reading X2 ?? 1 mile shows as 2 miles
I did not know this function was available so I tried it on my 2012 Roadster. Doesn't change anything except for resetting clock and trip odometer. Is there any special way or number of clicks on the button to change the Kilo/miles scale. I'd love to be able to switch to mph when in the States. My speedo doesn't have both speed scales showing like many do.
maybe you have to have both scales.
Well, I don't know, but I think I just pressed it one time, holding it in, and the display changed from kpm to mph. Also, my odometer was reading about 34 K miles, now reads 28 something...... oh for the old days, a cable running to the front wheel, NO electronic BS....... yea, and points and a condenser too !!! ha ha ha:laugh::laugh::laugh::laugh::laugh::laugh::laugh:
don't feel bad, i gone one worse for you to feel better about
I used to work for Summit Anchor (doing fall safe anchoring on high rise buildings) and one task is to come back to new or old installs and putting a chain ratchet and a load cell and a digital level on the posts and test them against each other and check how much they move (lean) Test must pass less than 0.10 degrees at 3500 lbs of tension on the load cell.
I ended up on a phone call because ONE of the posts was failing at 0.21 degrees at 3500.... i ended up eating SH!T that day for this but i had mistakenly put the load cell in KG and when that happens we damage the load cell. i ended up buying a damaged $1,500 load cell that day and for ever more had the shame of wasting the bosses time and a very expensive engineer phone call for 30 minutes and i even told them i had checked... Mistakes happen!
