@Neville Lush I believe you got this sorted by getting the existing one fixed according to a later post of
@Mittzy.
From what I have seen
NOT ONE online dealer parts listing appears to identify the correct ECU part numbers for Roadster models.
The key issue to determining suitability besides
@HansO 's earlier post re Tunes, is the VIN that MUST have the correct VIN code for ABS inclusion models. A key point of confusion is that US/Canada VIN are different than UK and the rest of the world despite sharing 17 characters/digits. The US system uses this system and a check digit which is not used for UK/Rest of world VINs.
the link .pdf launches and may appear blank (zoom in to see text), which identifies VIN number codes for every Bloor onwards(?) Triumph model including the Rocket 3 codes below. The 4th, 5th and 6th digits on USA/Canada VINs and same codes on 6th, 7th and 8th digits on UK/rest of world like mine posted above for a 2010MY Australian sold Roadster ECU dated 12/2009 SMTTLC0235A432260
C00 = ROCKET III
C01 = ROCKET III CLASSIC
C02 - ROCKET III + ABS
C05 = ROCKET III TOURING
C06 = ROCKET III TOURING & ABS
Model year Alpha character in 10th alpha/digit for USA/Canada and the 11th for UK and rest of world. 2010 is A, 2011 B. 2012 C, etc to current 2018 J.
As
@HansO advised the base tune is also different for 2010-2012 Roadsters and 2013 and later Roadsters. I am not aware of a further change to later Roadster base tunes but Hans should know.
I just bought a second hand 2016 Roadster ECU from the USA eBay for US$215 using the eBay 10% discount code PRESTO
Link Removed
They had a good photo of the ECU part number and it does not show tune codes like earlier ECU's.
The VIN is USA/Canada: SMTC02L4XGJ730141
Part Number: T1290216
Tune: Not stated
@HansO I am wondering if putting this 2016 ECU inn my 2010 MY Roadster and re-setting with TuneECU will allow me to use later Roadster base tunes releasing the secondaries in lower gears?
