Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
I won't go into specific timing event values, because, the values that work well on this engine were given to me by Neville and not my own product of testing.
They are the magic to making an engine run well.
Also keep in mind ramp rates at different areas can make two otherwise identical cams perform very different.
Imagine a straight shoulder cam with a wide 20 degree nose compared to a cam with massive shoulders that achieves .200" lift 15 degrees longer than the other but has a pointier 6 degree nose. With identical peak lift and duration at .04" numbers, the second will kill the first in power production if the intake runners have good low lift port velocity, as it has more area during the portion of the cam that is passed through twice. If the runner has garbage velocity but high flow at/near peak lift the first cam will do better.
Essentially the classic roller vs flat tappet cam debate of the V8 world.
