Incredible gesture - good for you
@tribal - Just hope that they don't try to stick you with that charge for the stator
Also - once you have it started, if you feel safe riding without headlights on, then pull fuse 10 (it needs that fuse in to start but once running, you can pull it)
That will help you maintain your running situation. Without the load of the headlights (10A!) it should really extend your range.
alternative #1 to pulling fuse 10 would be to disconnect the two 4-way headlight connector plugs under the tank at the right side of frame just behind the steering head)
Alternative #2 is if you have a spare 4-pin relay - pull the 5 pin relay behind the right side cover and replace with a 4 pin - this will allow bike to start normally but not allow power to the headlights)
@TURBO200R4 - when it gets there, let me know if you &
@tribal need any help in affirming the diagnostics
