Mounting an Exedra Max rear tire on the new 3R = Better Handling
Update- I just did the first tire change since putting on the Exedra Max. I got a little over 5,000 miles on the tire, which for me is a record (based on my history with the Roadster). As usual the wear is mostly on the outside. I might have gotten a few hundred more out of it, if not for picking up a nail yesterday (good timing) and the fact that I often end up riding in the rain.
Not sure if it's because the bike is lighter than the Roadster, or because I put a lot of distance miles on it on a ride from NC to Washington D.C., New Jersey, and back that accounts for the increased wear over the Roadster with this tire.
What I can say is that the handling is definitely improved with the taller profile tire and I have always liked the performance of the Exedra Max. Needless to say I mounted another Max.
Above, the Exedra after 5,275 miles.
By contrast, the original Cobra (below) with just 3,150 miles racked up during the break-in period.
That's good to know as i have an Exedra Max curing in my shed!...seems like low mileage your getting tho!...12000 kms for my cobber on his R model..Avon...then a Metzeler 888..another 11000kms....23000kms on his front Avon.
It the same thing I was thinking to do next year on my bike but I’m interested in ABS on dashboard do not throw any warning lights??? 240/50/16 chrome vs 240/55/16 exedra 1” taller in overall diameter???? Only two spacers 1/2” thick to replace it on bike without any issues?? Thx
how big of an effect did have on the speedometer, it would be nice having an alternative tire to go to, chromes always seem to be on back order here
No ABS warning lights. The Exedra is 1" taller, so it lifts the bike 1/2" (figure 1/2" above the axle and 1/2" below- the 1/2" below is what lifts the bike higher). But, I may lift the "hugger" another 1/4" (to 3/4") for a little more clearance there.
My speedometer is still reading faster than I am going. At 70 on the gauge I'm really doing 68. I don't mind it- better than reading too slow. Not sure how much the larger diameter tire affected the discrepancy.
The forward fender (hugger) is such an easy mod and completely reversible. There's really no reason not to at least try the Exedra Max. Lower cost, longer wear, and improved handling (decreased rake caused by the raised rear).
Thx for quick reply and chance to save on tire cost and all + and- off doing it!! Appreciated
Maybe a little better lean when on side stand also?
That’s not bad. With stock tires my dash reads 5 mph faster than true speed
