Most efficient mods question...
Thanks! I will look into that!
So, not really finding the "slip-ons" you are referring to. Is there a contact or perhaps a link to that solution? Thanks!
I've seen some people get a Supertrapp muffler to slip on the end. There are cheaper generic types too. I'd check ebay or JCWhitney
Supertrapps come with a generic bracket, that once you decide where it needs to be, you get it welded on! Kind makes the "slip on" moniker a bit questionable...but I DO like the fact that you can get exactly the back pressure you need for your state of tune, just by adding or dropping discs!
THE problem we found was you can not make the max power that can be made with other exhaust systems and they dont sound that good either
Was not aware of that...maybe even wide open they don't have enough space to puff out the exhaust a full bore Rocket 3 cylinder can produce!
The problem is not with the slipon, it's the stock exhaust manifold that doesn't flow well above 5000 rpms. But getting a full exhaust system will probably put you above the cost you said you wanted. But if you are happy with lots of low and midrange power the stock manifold will work. Just get rid of the heavy and restrictive ends.
The Auto Tune will adjust to your exhaust as it follows the AFR map
I use a mixture of widows and Apple devices but I just bought a basic 10 inch windows LapTop for tuning use was very cheap and works just fine, if you dont want to do that I am sure there must be someone near you that can help you with a suitable device (Windows or Android)
Yes, Yes - I got an Android Tab for $99 & it is simple to use for my simple non-Tech mind - recognizes the LonElec cable on it's own too!
