Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,964
- Location
- Ride
Yes, I have been looking at the possibilities in there...
I had a very similar problem as you did with two replacement Chinese R/Rs in my Roadster (but thankfully was only stranded a few miles from home). After gratefully receiving similar advice from @DEcosse I fitted my SH847 AA a couple of days ago.
As advised it was much bigger than stock and no way I could use the same position or mounts. In the end I wrapped and fixed some felt backed rubber around the rear frame tube and zip tied it in place behind the side cover with the much taller fins faced in where they will hopefully get some air coming past the prop shaft drive.
Will this suffice or do I risk cooking the other electrics? Where did others mount theirs?
Happy to say that voltage measured at my accessory plug is a happy 14.3 volts with the engine running and headlights on etc. Voltage with engine and light off 13 volts.
The rat's nest of wire in my air-box is the excess of an accessory two light wiring loom I should probably cut out.
. Now I'll read the rest of that great thread that
