DEcosse
If it's no Scottish it's CRAP!
.... The as-delivered ignition switch has a 'run' position and a spring-loaded 'start' position.
OK - you mean the bar switch as opposed to the key-switch i.e. the Run/Kill switch and the Start switch
Whether you turn off the key, or turn the Kill/Run to Kill, the actual 'ignition' circuit breaks at the same node (they are actually in series in the conventional OEM set-up)
The main difference between the key-off and 'kill-off' is that the key additionally breaks power (through separate poles) to non-ignition circuits i.e. the lighting and ancillaries (horn, turns, brake etc)
Might you explain how yours does this? For example, sometimes, if the bike has been sitting a while, it can be useful to have the fuel pump cycle a few times be turning the key to 'run' without starting.
Well, I would debate the requirement of having to do this - the pump runs for several seconds when ignition system is first powered and should be plenty adequate time to bring the fuel rail to pressure.
However, if you needed to do this, you would do essentially the same thing:
The difference now is that the Kill/Run switch now controls ALL the functions - instead of the Kill switch only being in the main 'ignition' circuit, it also interrupts the feedback to my controller, which keeps the ignition system latched on; so setting to Kill actually drops all the relays (including the one providing power to the Kill/Runswitch to begin with!) mimicking the same effect that turning off the key would have had.
So - you just want to do the same thing, which is simply turning the ignition on, then off, then on again:
System dis-armed (which it would be automatically if you are at bike with remote on your person)
Kill Switch to run
Pull (& release)* clutch - ignition system turns on (fuel pump will prime etc)
Set Kill/Run to Kill - ignition system turns off
Set Kill/Run Switch to Run
Pull clutch - Ignition system turns back on (fuel pump will prime again)
Press start then release clutch.
* For normal starting you wouldn't typically release the clutch - in one action, you pull clutch, let it complete its prime, then press start & release clutch when started (as you normally would)
As I think about it you wouldn't even need to release the clutch to do a double-prime - set kill to run, pull clutch, ignition comes on, primes, set kill to kill, set kill back to run, ignition comes on, start & go.
Also, after installing your kit, I presume one would still carry a key to use the bar lock feature, as well as secure the paniers (R3T here) ?
Yes of course.
On my own bike the only thing I use key for is the gas-cap. I removed my switch completely, I prefer a disc lock over the key-switch lock anyway (a xena xx14 with the motion detector alarm is my own choice);
for the seat I have a solenoid operated system (like a car trunk pop) in place of the original key-lock for that.
