atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 3,031
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
When you use the kill switch it opens the ignition circuit cutting power to the ignition coils. The neutral light won't come on with the kill switch open, nor will you get a gauge sweep or normal dash lights. If you use the kill switch, make sure the switch is back in RUN before you turn the ignition key to ON. If you go the other way it's possible to fool the ECM into a fault condition.
