R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,376
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
72. Run the supercharger outlet hose across the front of the engine, tucked under the lower radiator mounts, and up over the engine coolant expansion bottle, under the left chassis spine to where the oil filter will be
73. Fit the oil filter, taking care to have it in the right direction, and the hose from the oil filter to the outlet (bottom) of the canister/bottle/catch can
74. Now the traction fluid / oil circuit is complete, ensure you have jubilee clips, ear clamps or similar to hold the oil hoses onto the fittings all around the circuit
75. Follow the Rotrex instructions for priming of the oil circuit;
Note: I used the El-Cheapo method of a plastic syringe with an o-ring superglued to it, as a fitting to go over the spout of the oil canister (in lieu of a proper hose tail barbed female fitting), and fed it from an air compressor whose outlet was regulated down to about 10psi – I found that the oil level in the canister dropped from MAX level to MIN level mark when priming was complete i.e. fluid came out the supercharger oil inlet – and then after topping up the canister again to MAX mark, found I had used just over 500ml
