Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
Not all DOT/Snell helmets are created equal, no matter what the manufacturer/vendor says it is a minimum standard. DOT only has to take 1 hit, Snell is required to take multiple hits, are really sure you will only bounce your head off the ground once? Just food for thought.
To reiterate: DOT is absolutely NOT the equal to Snell. They are similar, but Snell is superior and much harder to pass for manufacturers. DOT tests a sample chosen and sent by the manufacturer, who is then trusted to maintain the standards used when building the test sample. Snell tests a random sample and retests regularly without informing the manufacturer using off the shelf samples.
As to how much to spend, there is no correct answer, but in order I think these should be the priorities that will get you to your "right" helmet:
1: Does it fit properly, if not find another helmet. No exceptions, an ill fitting Shoei vs a good fitting anything will perform worse than the generic.
2: If it fits properly, try to find a carbon shell, if you cannot, look for fiberglass, if you still cant find one that fits properly made of composites, then and only then go to poly (plastic) shell helmets. Poly is great for the initial impact, but performs much worse on subsequent impacts.
3: Is it comfortable? If not, put it back on the shelf and keep looking. If it is, continue on. No one wants to wear a uncomfortable helmet, and it will deter you from wearing it properly and possibly from riding as much.
4: Price, if you have found multiple helmets that fit right and are made of carbon, glass, or a mix of both, pick the one you can afford.
5: Color, picture, graphics... whatever. These should be the LAST thing you even think about. They are 100% unrelated to anything except your ego. You will look much cooler walking away from a hard crash wearing a pink helmet, than you would look dead with brains falling out in a flat black one with a "badass" graphic on it.
My helmet: http://www.revzilla.com/motorcycle/nexx-xr1r-carbon-helmet
I've owned Shoeis Arais HJCs and Sharks, for me, the Nexx is vastly superior to all. Equal comfort to my $900.00 Arai, lighter than all others, better Aeros at high speed than all but the Shark, and SUPER quiet as a result of the integrated oversized neckroll. Plus... it's fawkin sexy!
