Help stuck on tuine ecu remap file
If Australia is in the Argentina/Indonesia/S Africa, then wouldn't your US map not be suitable for me?
Also in the picture i attached do you think there is a typo (in red) in the 31018 map warning. It sounds like it shouldn't be used in any region. Or are there more regions?
Oz is in the Argentina/Indonesia etc region. The OEM Map is 31023. I copied the tables from the latest (after vin av5457) Penner R tune for the US into your base map. Thus, you’d be using the correct base map for Oz but with Penner’s most recent tables. Note that with the OEM maps, all of the tables are the same for the R and GT across regions. You will be fine with Penner’s US R tables.
Australia is in the Argentina/Indonesia/S Africa market so 31023 is the correct base map. If you want to get a Penner unrestricted tune, you should get the latest Penner tune for the R from the Tuneecu.net site and copy the tables from it into your 31023 map. Actually you don’t have to do it. I copied Penner’s latest US R map into 31023. Send me your email and I’ll email you the
Okay, but my VIN is 986885 which would before vin av5457
Yes, and the base map 31023 is for your vin and region. The OEM fuel, ignition, throttle, etc tables for the pre and post av5457 are exactly the same! Penner’s unrestricted tunes for the post av5457 vins are more consistent and make more sense than his earlier maps, which contained some errors. That’s why I prefer the tables from Penner’s newer tunes.
Write your reply...
