Garmin Gauges ecoroute
I also had the Autotune installed and was using Hanso's table as a base map. I found that after accepting the changes, over time, I was noticing some dead spots in throttle response. It ran good but not as good as with my Wayne Tripp tune. I thought by installing both I might be able to improve my gas mileage which was and is currently around 28. Expensive experiment :kk:
We're you trying the version 2 or still the first version and as I have told other people try running it with out accepting the trims unless you set I up like Chris where he activated the by gear function, if torun it as I do (without the by gear acivated)it will lean off differently in different gears as you ride but then you accept the trims it will not be right, went thru the hassle but found that ifyou do not accept the trims it is always smooth as.
You do not have to accept the trims
The Rep said he swnt me a formmro request that their engineers consider it. I did not get the form so I responded to get the dorm again. Maybe if we all put our two cents in we can get them to work on it.
