Journeyman
Here's some late night reading material that came up after some Googling results- after all, this is probably a Triumph thing, not just the Rocket3...
www.thetriumphforum.com
www.triumphtalk.com
www.triumphtalk.com
www.r3owners.net
advrider.com
"The clutch switch is one of those switches from Triumph that is used to do a whole lot more than just tell the computers that the clutch is either engaged or not. There's about 14 different things on the bike that use info from the clutch switch from fueling to gear position."
There are two part #s
$161.14 (includes the harness - I think) 2011 Triumph Rocket III Switch Set, LH. Controls, Clutch, Switches, Suspension - T2046759 | HERMYS TRIUMPH eSTORE, Port Clinton PA
$110.72 (requires splicing- I think) 2011 Triumph Rocket III Switch Set, LH. Suspension, Controls, Clutch - T2046018 | HERMYS TRIUMPH eSTORE, Port Clinton PA
I remember when mine was apart a small "shaft" that seemed worn down. I'm wondering if I can replace that with something else to get the existing switch going again. Thinking maybe as it is now the ECU sees that the clutch lever is in and starts, but does not see that it is out, or something like that- I'm totally making this stuff up
I just ordered one from Pinwall for $55. We'll know soon enough if that is the fix.
Tiger 1050 Fuel Gauge/clutch Switch
I took ownership of a 2008 tiger 1050 about 5 weeks ago. The bike is in great condition, with the only issue being a non functioning fuel gauge. The...
Fuel gauge reads empty fault - cause ASV C5 Clutch lever
I found this on the Tiger800 forum. I thought I'd pass it on. It might help someone who is changing clutch levers. http://www.tiger800.co.uk/index.php/topic,7543.msg101607/topicseen.html#new The poster replaced his clutch lever with an ASV C5 lever. He had a problem appearing with his...
Will Not Start if Fuel Gauge Does Not Register
I compiled the following from several different sources. It is anecdotal; I haven't found anything official about it. It seems that the Tiger 800's and XC's will not start if the fuel is not registering. Fuel not registering can be caused by being out of fuel, of course, and by a weak or dead...
Want to Buy - *NO LONGER NEEDED*Clutch Switch
My switch broke recently. I have it bypassed right now to run the bike but I don't like my fuel gauge being inoperable. I know it comes as part of the entire switch assembly do in willing to buy that. However I really don't want to spend $160 just for the switch. Anybody got one they are willing...
Triumph tiger 800 xca 2018 will not crank
Hi all need help. Have triumph tiger 800 xca 2018 and when I turn on key I have dash come up. Fuel pump noise and all the other normal key on clicks...
