Frustrated
Yep the Triumph one:
Has been out of production and availability from dealers for many years.
SILENCER UPGRADE A9600160
Suitable for US market only. Can only be installed with TORs Accessory Silencers A9608060
Link Removed
Link Removed
I have a similar used aftermarket 3 pipe stainless cat delete version for US$280 delivered to the USA.
or Au$300 plus postage if someone wants it.
Link Removed .
STAINTUNE
Yep, Great system, but a bit expensive if he just needs a good cross pipe for his TORs :
For Sale - Staintune triple pipes and cat delete crossover - All Stainless.
New Aussie RRP Au$ Price:
Triumph Rocket III
TR MS ROC 3P 2004 onwards Triumph Rocket III / 3 replacement slash cut style mufflers Removable Restrictors SET $1,785.00
TR CB ROC 3P 2004 onwards Triumph Rocket III / 3 into 3 Performance Spaghetti Collector Each $800
Trying to insert the filter under the box is a female dog!
For 7+ years I have used a foam filter cut to fit the bottom of the box. Clean every season. No issues with oil, grime or rust on tools/metal parts carried inside.
Good advice!
not much I can do until tomorrow and I’m now 250 miles away at my parents anyways.
Does that look like a valve cover on the table with blue to the far right?
Update went out early this morning to take Wendy's rear wheel off her bike to get a new tire to put in it
When I got it off I decided to try again on the air box and I'll be dam if it didn't just slide right together
When I get home from having a new tire put in Wendy rim then I'll try to tighten everything up and hopefully it will stay together
If it don't and u don't hear from me anymore that probably means I blew everything up
Tune for ramaire plus tors can be found in the resources tab
Would this tune work for the Ramair combined with the shorty exhaust from British Legends? If so, what’s the best way to DIY, or should I have a shop do the tune?
Sorry guys I forgot to add --stand back 200m before the explosion
mid you look in the tune resources you may find one for shorty exhaust, I don’t know.
If you can find some YouTube videos on running the tune onto your Ecu that would help you
