Free unrestricted maps for Rocket R GT and TFC now online
Yes, I purchased the app, registered the bike, and found the option to remove the speed limiter on it. What I am unsure of is how it actually works when I go through with it. Will it change the existing map on the bike? I want to put the Penner map on, but haven't done it yet. I want to make sure I don't spend the money to remove the speed limiter and then flash with the Penner map and undo what I spent the money on. I will contact the developer. Thanks!
You can’t read or do anything to the map in the ECU. You have to read in a map into the app, like the Penner tune for the USA GT, uncheck the speed limit under parameters, then download the map to the ECU. I don’t think you will be able to uncheck the speed limit box unless you pay more $$, according to Alain Fontaine (the app developer). If you can uncheck it, it may not “take”.
Ok. So I purchased the speed limit removal from within TuneEcu, and it comes attached to a stock map. Per the developer I now need to modify that map with the tables from Penner's tune to be able to use the the Penner map along with the speed limiter removed on the bike. I honestly have no idea which tables or how to copy the tables from Penner's map into the stock map. Anyone have any tips or ways to make this foolproof so I don't mess it up?
TuneECU has a function to export the tables, when you open the map the F1 table is displayed. You can tap on F1 and it pops up a list of tables to switch to. once you select a table under the Table menu is an export function. I can't find the post where Penner said which tables he'd modified (I think it is just F1-F3), but to be safe you could just export them all and import into the map without the speed limiter.
I will see if I can find the post that discusses the tables that were modified. I have someone who has offered to help as well. Thanks much for the response!
From pistons up everything is diff oversized valves custom cams full ported head throttle bodies bores full exhaust designed for much better flow clutch plates and basket upgraded off the top of my head
Did you get anywhere with the rev limit? Alain will now sell you a stock map with the speed limit removed. Perhaps he would do the same with the rev limit.
