barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Oddly the first thing I went to look at on GOC's screen shots was the vacuum values. They are all even - but (and this may or may not matter) all seem a bit low compared to mine. Last time I looked - mine were in the 670'sFirst thing to check is the throttle bodies' connection to the boots on the head. If a TB is loose in its boot and leaks air, nothing else you do will matter. Ask Boog. If the RAM air has been on and off more than a whore's panties, you may have dislodged the TB in their boots in the process.
Next would be all port caps and vacuum lines. A cracked line can open and close with changing vacuum and will drive you nuts. Loose caps on the unused ports on the TB can also be a problem. If there is a leak, the sync could be off too but only at times so find the air leak and then re-sync..
@Grumpy Ole Codger - a good source of vacuum tubes is Morgan Carbtune - carburetor synchronizer for balancing motorcycle carbs - one of these days I must try the @Speedy inspired vacuum plenum. I'm lazy, OK!.
Also imo - makes NO SENSE going to a Dyno man if there are any issues. It's maybe a BIT extreme - but given your admissions of diminished capability - replace all the **** vacuum tubes. I would pressure and vacuum test them but because I have access to the gear.
