Dyno numbers - 2.5inch Headers vs Stock headers
I would say the data doesn't mean much because there were too many variables. To have real meaning you need to have a run, make the changes and then make the run again in a much shorter period of time.
you mean quartermile?
what I dont understand is throttle response on the bike with open headers is way better than before, huge difference, I move throttle at any gear and it goes which was not the case before.
Second, with open headers my MPG has gone 30% down than before so I need 30% more gas per fill if I want to go same distance as I was going in one tank before open headers.
Less back pressure has improved throttle response. I may have missed the tune part but it sounds too rich now. The most important thing is, how does it sound?
The max torque for the original run was 145. The max torque on the recent run was 160. That’s a significant difference.
As Stingray mentioned, could that 160 lb-ft simply be a momentary spike?
The last dyno i had there was a torque spike, a big one, maybe thats why i jammed my torsional damper? Lot of torque, 3 spikes actually, on every pull we were getting crazy torque numbers at the top. This package ate a torsional damper and then at end of summer ate 4th gear. I had a billet one in and trans shaft gears still broke.
alright, can some one explain why my gas consumption has increased by 30% with new headers and open exhaust? and my riding riding is same as before, nothing changed.
Write your reply...
