This subject may have been done to death elsewhere so please excuse me if it has. So as I am changing my rear tire at mo, I decided it was time to lube the Driveshaft Splines after seeing this post come up. Took the wheel off and then dropped the LH shock and unbolted the dif. I can easily access the rear spline. It was almost completely dry.
My questions are.
Can you just pull the drive-shaft out and off the front spline from the back? (if this makes sense) I have tried pulling it out but its not interested, checking the exploded view it looks like there's a universal coupling at the front thats probably stopping it?.
Do I have to pull the entire swing-arm out to get to the front splines? Also if I have to pull out the entire swing-arm, how much of a pain in the ass is it?
I'm pretty sure the molycote will not be a problem here as we are stuck in time so someone will have an old container lying round.
Thanks in advance
