1K9
No'mo Rocket 4 me
MOTORCYCLE tires and rims are designed to lock together so that in case of a quick loss of air the tire will remain locked on the rim to prevent loss of control so you can come to a safe stop CAR tires do not fit on motorcycle wheels correctly and will not lock on as they are a different configuration and are designed to lock on CAR rims . The fact that you dont ride much is not going to change anything or make it any safer even though you exceed the speed limits by not much . so it comes down to saving money and not being as safe on the bargain basement tires . AND your doing this on the Almighty Rocket the largest displacement production motorcycle .
IMFASTOO; Thank you for your reply.
This is the guy that started the whole thing or at least started publishing material on dark siding. The Dark Side
Wow, did a Google search on the issue and all debates get heated pretty rapidly. Could not find specific cases of "catastrophic failures of car tires installed on motorcycles".
I understand the bead adaptation issues. Are there any known cases of spontaneous separation that you know of? Better yet, do you know of any of these cases?
I will try deflating my CT and see if I can get if off the rim without a machine. It was hard to get it in there.
