Couple of possible issues
Great Advice! Thanks
G'day and welcome.
Does it jump out of 2nd gear when accelerating or just feel clunky?
It hasn't jumped out of 2nd gear, but I find it hard to engage first and sometimes it jumps out of first.
Was the R3 sat for a while without being used? - sometimes the pads bind slightly onto the disc if left sat idle for a goodly while. This can take a while to rub off
I would imagine it has sat for quite sometime. With such little K's on an 06, Riding would have been very scarce on it.
I have done a few really hard front brake only stops trying to see if that will resolve it but so far, nothing.
On Another note, before I do some damage, where is the best point to jack the bike up? Under the Engine with a trolley jack with a rag over the jack or something?
Cheers
Cheers
..argghh..another pita design..if ya just wanna raise the front wheel, yes, you can put jack under engine without due cause for concern....but..if ya wanna raise the whole bike, that's whole other ballgame...do a search on here..lots of info..
I use a scrap 1 X 4 pine board between jack and engine. The wood gives enough the you won't break any fins or ribbing on the lower cases. Make sure you stabilize the bike with either wheel in the air, bad things can (and will) happen if you let it flop around in the breeze.
Thanks for the info and point taken. I am actually thinking of buying a proper jack. I need to jack my yamaha up also as it looks like it shat the rear diff or shaft a few weeks back.
Anyone in aus know where to get them at a reasonable price?
I think these kind are available world wide. They come from a place called Harbor Freight here. This is what I use. The trouble with the rocket is if you left just under the engine it will only lift the front wheel. If you make an adaptor like I've drawn below (I don't have the measurements here at work but can provide them). The adaptor sits on one pad of the jack and goes up under the swing arm pivot tube. The other goes under the engine and picks the bike straight up. It's very stable. They are less than a hundred dollars here. You have to right click the drawing and then select view image.
