Competition Werkes Exhaust 2020 R3
Had 7 Harleys in the past i changed all their exhaust for Screamin eagles, had no issue with performance only de-cel pop and not excessive ,Werke's know what they're doing .
What i'm trying to say is even if its not 100% without being remapped they must have got to a point where its not going to give race performance but will not effect the ecu .
Removing the cat in some of the earlier bikes featuring them (e.g. 2012 Victory's fitted with the 106 Freedom motor - where they were literally squeezed into same-size headers) would affect engine performance, most notably the amount of valve overlap due to the altered back-pressure and how that bears on scavenging exhaust gas. Most modern bikes now sport larger cats, specifically not to impede gas flow and mainly to deter motorbike/car owners from removing them.
Adaptation affects the entire rev-range. The latest ECUs continuously adapt to manifold airflow and pressure sensor readings (amongst others increasingly) in combination with what the O2 sensor(s) feed back, to maintain a chosen stoichiometric A/F ratio (e.g. 14.5) - to an extent even considering one's riding style. By resetting it after installing new slip-ons, the ECU will clear current adaptation values (throughout the rev-range) and readapt afresh - normally over at least 300 km. In the case of the KTM 1190/1290 ECU, with which I am more familiar, it will even readapt correctly when fitting a different air filter - no need to get a dyno-tune for that on those KTMs.
Loading a map, like Penner's, does other things. Like altering throttle-body behaviour, enriching the A/F ratio in specific rev/throttle load regions and adjusting other engine response parameters - specifically to improve performance and rideability, and move away from overly lean settings imposed on manufacturers. Performing a dyno-tune, in place or in addition to loading such a map, brings it all to even a higher and more individualized state-of-tune.
My 2007 Rocket Classic had Jardines and triple K&N’s. The A/F at peak torque was over 15 with the TORs tune. The narrow band can’t adjust this down to the 13’s
Agreed. My 2006 Buell XB12Ss incidentally features a Jardine pipe and K&N air filter as well (-:
DynoJet competitor, DimSport's, range of 'Rapid Bike Racing' piggyback tuners are clever enough to manipulate and work with narrow-band sensors and to adjust for optimal performance throughout the rev-range - seamlessly across open and closed loops. Proper plug-and-play, or install-and-forget rather, they have garnered an almost religious 'ride-it-like-you-stole-it' following amongst Ducati, KTM and now also BMW riders, both track and street. They do Triumph as well but nothing for the Rockets, unfortunately - neither Rocket III nor Rocket 3 - Rapid Bike,
But no hassle - we have our own Secret Weapon, Penner (-: I upted his ETV3 table a smidge and my Red Rocket truly goes like a bat out of hell now as well; Free unrestricted maps for Rocket R GT and TFC now online
i just noticed when i was cleaning my 2021 r3 that the screen has a crack on it as well FFS
so i have a 2021 r3 i have since put the VGT 1" bar risers in, Corban aftermarket seat and i installed the Hepco & Becker C-Bow system last weekend for saddle bags. I ordered the Comp Werks Exhaust and it is sitting at FedEx waiting till i get home, didn't get the baffles with it but i will get some before and after video's. i have read through this entire thread and was wonder if anyone has some feedback about the Werk since install and putting some miles on them?
