warp9.9
Pocałuj mnie w dupę
The wavey washer goes on the inside of the thrust face it keeps the lifeter shaft away from the end of the transmission shaft so oil flows thru. it fits loosley and is on all Rockets.
location below
now on the other side of the permanent thrust face is the needle roller bearing. so it has a nice hard surface to run on. then the washer which is the other hard surface for the needle bearing to run on. (sandwiched between) also the thrust washer protect the aluminum surface of the old style pressure plate.
Hope this helps
location below
Hope this helps
