Clutch bearing collapse
Woo hoo found it, good stuff in this one. Bolts, washers, strengths, loaded with everything needed to change these bolts. i sure am thankful for @warp9.9 tearing up stuff long ago and @R-III-R Turbo and his research and development. im going to the finals!!!
That lifter shaft is toast the burnt edges are signs of either no freeplay in the adjustment. Or some one has been pulling the clutch in a revving them motor showing off. So new lifter shaft new lifter piece (the newer style) Turbo supplied part numbers. And the bearing. Now before you order the parts inspect pressure plate bearing bore for damage especially the lower face of the bore. Replace if necessary. You might be alright on that but we need to see the bore.
Hows mine look ?
