R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,374
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
And they are standard thread M6 ISO-C bolts - Which is a 1mm pitch.![]()
Thank you Chris, well spotted, I made a balls of that note. Updated now so as not to spread misinformation. I also had x6 down instead of x5. Must have been smoking crack that day
Don't be fooled into using stainless bolts they are not typically high tensile unless forged and marked Gr8.8 or higher Gr 316 are far better than Gr304 - better to use high tensile carbon steel bolts if you are going to replace them and they will need to be M6 x 1mm ISO std. Gr: 8.8 or better
Thanks John that has me wondering, why would high tensile carbon steel bolts be needed when they're going into a small & fine aluminium thread?
Also what tensile rating are the stock bolts do you know?
